No Response from my car = No inspection sticker
RE: No Response from my car = No inspection sticker
I dunno for sure - I just emailed Brenspeed and asked if they do turn off the rear O2s by default, and if so get me in line for a test-friendly tune file. I don't have to get a test for a while, but I want to be ready..
SCT turns the O2s off by default- if the tuneer doesnt manually turn them on you get this issue for NYS inspection (happened to me in Feb) Tell brent to update your tune with the O2s on and upload it. run a driving cycle and you'll pass - BELIEVE ME BEEN THERE DONE THAT!
ORIGINAL: A_J
Yup, your ran lean because you still had the CAI on with the increased airflow - if you return back to the OEM stock tune, reinstall the OEM airbox too.. Or like others said, keepthe CAIon and get a modified emissions tune from Brenspeed.
Oh - and you should just be able to clear the code with your SCT..
ORIGINAL: Margarita Girl
Ok, back to stock, and drove around 30 miles and now my engine light is on. Code = too lean.[:@]
Someone suggested unplugging the battery. Next step put the stock air intake back on?
Margarita Girl you O2 sensors are turned off on all your Brenspeed tunes.
You have two otions:
1.) change your CAI back to stock airbox and flash your car back to Stock tune. run for 50 miles. this usually puts your car through the various engines cycles required
2.) call Brent and get a new tune, or set of tunes, with the O2 sensors on.
I did just what you did and got the error codes only to learn that that you need to revet back tothe stock airbox as well since most CAI require a tune and you engine will run like poo (and you will get the various 'too lean' codes)
DrunknRuckus
08-23-2015 10:05 AM
inyadreems
08-21-2015 09:10 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
