Whoever installed there own shaker, please check in
I am talking with a guy on another forum about getting his new upper and lower trim ring. Now my original one had tape for the outter trim ring. Let me know what yours had. Thanks alot
RE: Whoever installed there own shaker, please check in
Mine had tape on the outer ring also. I have removed and re-installed my trim ring 3 times. Each time I re-installed it, I installed new tape. I have not installed the 4 rivets that originally came with the trim ring and it seems to be holding togehter fine also.
My kit came with pop rivets.
They hold the upper and lower trim together with the help of the 3M tape.
I didn't use them because I modified that trim ring with a heat gun and I had to take a lot of material off the corners so it could take the shape of that bulge I have in the middle of that hood.
The lower trim is useless for my application.
You have to use some rivets on that deal
The upper ring had 3M tape. Once I lined up the upper trim ring, I simply pulled the red liner on the 3M tape. I could not get the holes for the rviets to linr up. I wound up drilling new holes and using slightly larger rivets.
Shifty Magoo
08-25-2015 03:08 PM
'stangdude
08-12-2015 01:27 PM
