Guys , please help asap!
RE: Guys , please help asap!
hope you have a set of guages, the system being low wouldnt cause it to make any noises. it would cool poorly or not at all. sounds like the noise is being caused by the mode and blend doors in the hvac assembly. if its cooling properly you dont need refrigerant.
Mode and blend doors? What do you mean? The whining sound comes from the engine bay but only when the AC is turned on. The compressor is not ticking and shes cooling well. What could it be? It almost sounds like an ambulance siren FAR FAR away, not very audible but just enough to notice.
ORIGINAL: jwog666
the mode doors direct the air to the outlets and the blend doors adjust the temp of the air. does it change with blower fan speed or engine speed?
