Sponsored by:
Sponsored by:
Change Differential oil
Old 06-10-2008, 01:39 PM
  #21
SCCAGT
SCCAGT's Avatar
Default RE: Change Differential oil
Just one note to add to this, about friction modifier. If Amsoil gear lube is used, you must use Amsoil Slip lok additive. I tried Amsoil Severe Gear, which is suppose to have a modifier in it. It chattered almost right away. Put in an additive from Oreillys and the chatter went away for only two weeks.
So I changed the whole damn thing out again, used Amsoil Slip lok, and havent had a problem since.
SCCAGT is offline
Old 02-12-2009, 10:40 PM
  #22
itchy5
itchy5's Avatar
Originally Posted by cefiro80
My father just got the FRPP Diff Cover and is loving it.
Does you father have an aftermarket Panhard rod? Does it fit with the cover?
itchy5 is offline
Old 02-21-2009, 01:06 AM
  #23
ShadyNinja
ShadyNinja's Avatar
I bought the "slip lok "wasn't sure if I needed it, I figured it would be worse to need it and not use it , than to use it and not need it.
ShadyNinja is offline
Old 02-21-2009, 01:59 AM
  #24
viperrmk
viperrmk's Avatar
Get all the bolts in and then torque them in an X pattern (sorry, forgot the torque spec...its not much though).
Its 33 ft/lbs...just did a gear install today. XD
viperrmk is offline
Old 02-21-2009, 09:22 AM
  #25
russje
russje's Avatar
I have a stock panhard rod, and just by sliding under the car and holding up the FRPP girdle/diff cover it looks like it should fit no problem. I'm having that and 4.10's put in Thursday I'll let you know if they have problems.
russje is offline
Old 02-21-2009, 01:03 PM
  #26
flg2010
flg2010's Avatar
This looks extreamly difficult and risky to do yourself.
I have around 12k miles on my 2008 GT and plan to get both the transmission and diff changed at 15k miles at the dealer. I think the price is going to be around $250.
While I can do the transmission myself my thoughts are that if there are issues at this point (I have an auto) I would rather have the ford dealer see it and stand by their work so a warranty repair would be undisputed. As for the diff its a lot of work and I'm not up to it. Besides problems there could be almost as expensive if not covered by the warranty.
Currently I am using Valvoline to do my Oil and use their best syn oil.
flg2010 is offline
Old 02-21-2009, 01:10 PM
  #27
itchy5
itchy5's Avatar
I have have an aftermarket panhard rod, although now that I think about it, I don't know why it would matter. I am going to change my diff and trans fluid soon and thought that the FRPP cover would be a sensible change since I have to take the stock cover off anyway.
itchy5 is offline
mtgldr
02-03-2024 09:00 PM
2007StangV6
01-28-2016 06:09 PM
MusicCity615
09-12-2015 07:05 AM
kevsgt
09-09-2015 06:20 AM
Quick Reply: Change Differential oil
