Sponsored by:
Sponsored by:
factory hood scoop installed on my 05 with pics
Old 06-11-2008, 01:25 PM
str8wick3d
str8wick3d's Avatar
Default factory hood scoop installed on my 05 with pics
The install was pretty much easy.. 10 holes to be drilled.. put piece of blue print paper on top of Styrofoam and pushed the hood scoop down onto it, then traced out the hood scoop on the paper and cut it out. Went to a ford dealer and measured how far to put the hood scoop down and began to install. I have to give people advice though, It is a 4 screw, 6 pin install. The 4 screws in the front, and only push pins to support it in the back. Make sure if you buy one used it comes with at least 4 of the push pins as 3 ford dealerships could not find these for me. You will need them! Originally you need 6, I only had 4 for the back. Still flush though I will be replacing these pins with normal bolt/washer/and nuts as I do not think they hold the scoop down tight enough. Anyways to the pics! On Camera phone but u get the idea.
str8wick3d is offline
Old 06-11-2008, 01:29 PM
Seabee
Seabee's Avatar
Default RE: factory hood scoop installed on my 05
It looks good, im glad it worked out for you
i sent everything as it was when i pulled it off, i wish i could have sent you replacement push pins too, i know a couple got screwed up
Seabee is offline
Old 06-11-2008, 01:32 PM
str8wick3d
str8wick3d's Avatar
ORIGINAL: Seabee
Hey man don't worry about it! 4 is all you need. Im going to replace the middle pins with the bolts/nuts as I said. Thanks again for the scoop!
Old 06-11-2008, 01:44 PM
Seabee
Seabee's Avatar
no problem, it looks good btw.
Seabee is offline
Old 06-12-2008, 03:04 AM
str8wick3d
str8wick3d's Avatar
Thanks! I think so to. Time for gt/cs bumper.
Old 06-12-2008, 08:58 AM
Kara
Kara's Avatar
Looking good
Kara is offline
Granatelli Sales
01-20-2020 12:34 AM
P51_GT
ROUSH Performance
24
04-06-2019 09:19 PM
SYNY5TER
09-02-2015 01:35 AM
kdryan
08-21-2015 04:01 PM
MustangHead91
08-16-2015 03:20 PM
Quick Reply: factory hood scoop installed on my 05 with pics
