how to install a gt stock grill ?
I currentley have the eleanor center foglightgrill and today im going to install back the stock grill. Do u have to take the bumber off? Its it hard to connect the foglight to the gt grille ?
RE: how to install a gt stock grill ?
just remove the radiater cover then you have a few taps to pull out just be carefully so you dont break anythign but it should take you like 15 min its not hard
alright thanx guys, i also remove the cdc decklid rear panel its a pain in **** to take off, so much adhesive totake off.
no more cdc decklid black rear panel
[IMG]local://upfiles/75778/AB830FB68BF94A488FC5FCB2849EFF52.jpg[/IMG]
Some unmodding being done to make way for more mods
Remove the radiator cover. Remove the two bolts on the
top of the bumper cover next to the headlights.
There are two tabs on each side of the grill that snap
into the bumper cover. Along the bottom edge of the grill
there are 3 - 5 tabs that need to be released. A small
screwdriver helps with getting the tabs out. Be very careful
not to bust any tabs off if you plan on selling or reinstalling the grill.
thanks a-lot i just finish removing center foglight grille with stock gt grille. Its not hard at all even a cavemen can do it ![8D]
ORIGINAL: 157db
'stangdude
08-12-2015 01:27 PM
