Sponsored by:
Sponsored by:
How much brake fluid do I need?
Old 06-20-2008, 10:27 AM
Argonaut
Argonaut's Avatar
Default RE: How much brake fluid do I need?
ORIGINAL: drbobvs
I wasn't planning on changing the lines as I do not track the car, just need enough to get me down from a few 110mph runs at the 1/4 track or other places(). I will be sticking with the Brakedesigns rotors and HPS pads I have now, but i will say I think the Akebono Ceramic pads i had before, while did not have as much stopping power as the HPS, did not fade like the HPS did the other day.
Am I correct to assume you can't bleed the lines the way they are now? You definitelyneed these special bleeders, or do they just make the process easier? Can you pick up a bleeder kit as Autozone or Pepboys?
You can bleed the brakes without the speed bleeders, each caliper has a bleeder valve, it just takes two people - one in the car, the other opening and closing the bleeder valve screw.
Argonaut is offline
Thunderball
15
11-22-2015 11:49 PM
Matt's 95 Stang
10-05-2015 07:16 AM
wraith777
09-28-2015 10:49 AM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: How much brake fluid do I need?
