How much brake fluid do I need?
....to flush the entire system? I will suck out the reservoir and fill with new fluid and then bleed the lines from there. I am runningdrilled rotors and HPS pads and, after an episode of significantly frightening brake fade today, I would like to change to DOT4. How much do I need, and any particular brand you recommend? Thanks.
RE: How much brake fluid do I need?
ORIGINAL: sevenleaf
Is this as simple as sucking out the res, then connecting a bleed kit to that plug on the caliper?
I couldn't suck out the fluid in the master cylinder because there is a little baffle in there, didn't try to remove it though. I bought the Earls Speed Bleeders, they really help. You'll need a piece of small, clear rubber tubing to go from the bleeder valve into a coffee can or some other receptical. Start with the right rear, open the bleeder and start pumping the brake. Once the master cylinder gets a good way down top it up with Super Blue (yes it is Blue in color). Keep pumping and filling until the blue is coming out of the bleeder valve. Tighten it down and go to the left rear. Go thru all four corners. At this point you can button it up and drive it a few days. Then bleed it again a few pumps each corner, this is to get any of the old fluid out of the ABS system, or at least as much as possible.
Did you by chance get SS brake lines too? that will help pedal feel greatly IMO..... J
ORIGINAL: drbobvs
I found russel's speed bleeders at jegs but have been unable to find earl's for our car although I'm guessing russel's would be fine. This thread came at the right time for me as Ive had the car for about a year now so it's time to flush the system anyways. I'll be swapping my lines as well,they have been sitting on my shelf for months[8D]
I wasn't planning on changing the lines as I do not track the car, just need enough to get me down from a few 110mph runs at the 1/4 track or other places(). I will be sticking with the Brakedesigns rotors and HPS pads I have now, but i will say I think the Akebono Ceramic pads i had before, while did not have as much stopping power as the HPS, did not fade like the HPS did the other day.
Am I correct to assume you can't bleed the lines the way they are now? You definitelyneed these special bleeders, or do they just make the process easier? Can you pick up a bleeder kit as Autozone or Pepboys?
