Is There a way ro get the 4.0 a 12second et without FI
RE: Is There a way ro get the 4.0 a 12second et without FI
ORIGINAL: schapman
nitrous would be the only way if you didnt want to goFI.
That, plus gears, intake, tune and some DR's with at least 250 shot. By then, with that much though, boom!!!
Unless you went H/C/I Tune, and all Supporting mods, then you can do it N/A from being bone stock.
RE: Is there a way to get the 4.0 a 12sec ET w/o FI
With supporting mods (tune, CAI, gears, LSD, tires), you can reach mid-to-low 13's with only a 100-shot. There have been a few members here & elsewhere who have done it. One I can think of off-hand is in the high 12's, but he may be running a 125-shot. That's about as high as you should go, and even then you'd better have a proper dyno tune, window switch, etc. That 4.0L will go POP otherwise.
The quickest N/A 4.0L runs 13.8's. Head & cams can be done, but no one has ET'd their h/c 4.0L with results to brag about.
There are several great options for FI (superchargers and turbos), which will put you into the 12's without breaking a sweat. It only takes money.
