Sponsored by:
Sponsored by:
Eibach pro springs......rides like a pogo stick
Old 06-19-2008, 09:15 AM
mykld214
mykld214's Avatar
Default Eibach pro springs......rides like a pogo stick
Perhaps I jumped the gun a little. I added Eibach Pro kit. Now my ride is something like a pogo stick. i should have thought about shocks at the same time. Which ones should I get ? I've been advised of an adjustable panhard bar as well, both for and against by the way. What does the pan hard bar do anyway ?
mykld214 is offline
Old 06-19-2008, 09:22 AM
Simon1
Simon1's Avatar
Default RE: Eibach pro springs......rides like a pogo stick
The panhard bar re-centers the rear of your vehicle. The reason it rides like crap is because you didn't get the shocks/struts done.
Most here probably use the Tokico D-specs, I do and like them. The Koni's have a good following and no one complains in the least.
Simon1 is offline
Old 06-19-2008, 09:48 AM
mac10chap
mac10chap's Avatar
eibach pro kit with tokico d-spec's here...love them and made the car handle and ride 10x better
mac10chap is offline
Old 06-19-2008, 09:55 AM
GT/SRT
GT/SRT's Avatar
What would be a good price for both together?
I already have a shop that will install everything for $150- I don't have any tools or a place to do it.
GT/SRT is offline
Argonaut
Argonaut's Avatar
Yep - D-Specs or Konis. The PHB prevents the lateral (left, right) movement of the rear axle. Because it swings in an arc, lowering the car has the effect of moving your rear axle slightly to the left (drivers side). This may or may not be a problem depending on where the axle was from the factory and the width of your tires. In general you will want an adjustable phb to re-center the rear axle. The phb will neither hurt nor improve the "pogo" effect you are currently experiencing, its the dampers you need.
Argonaut is offline
Old 06-19-2008, 10:01 AM
Argonaut
Argonaut's Avatar
ORIGINAL: GT/SRT
Springs are ~$200-250
D-Specs ~%500-550
Koni Sports ~700+
Prices can vary, need to look around, wait for a sale, buy used, etc.
Argonaut is offline
Old 06-19-2008, 10:16 AM
AmericanSpeed
AmericanSpeed's Avatar
Have the D-specs and Steeda lowering springs. Still a little more bouncy than stock, but that's just the trade off you take with lowering. +1 for argonaut on the adj PHB explanation.
AmericanSpeed is offline
Old 06-19-2008, 11:32 AM
teksp0rt
teksp0rt's Avatar
you can also get the Eibach dampers to go with your springs...
They offer an entire suspension set-up... I agree, the ride sucks with just springs....
I went with the Pro-Kit Plus... It was springs, sway bars, & Dampers.. Everything worked well together.
http://store.summitracing.com/partde...p;autoview=sku
[align=left] [/align]
teksp0rt is offline
Old 06-19-2008, 12:28 PM
one eyed willy
one eyed willy's Avatar
bunch of sissys!
one eyed willy is offline
Old 06-19-2008, 12:51 PM
Chris07GT
Chris07GT's Avatar
Word up *****! If I wanted a smooth ride,I would have bought a different car!
Chris07GT is offline
Quick Reply: Eibach pro springs......rides like a pogo stick
