CAI C&L Sound, is it normal ?
Hello !
I own a mustang GT 2007 Manual and bought C&L plus tune from Brenspeed.
I keep listening an air sound coming from the CAI since i installed it and been wondering since, i want to know if this is a normal sound or not.
If the car is idle and press gas i can hear like air coming from it and while driving changing from 2gear to 3gear sometimes i can listen to it, is this normal ?
What is the behaviour when having leaks in the CAI ?
***__ I forgot to ask you guys if you can hear that sound also when turning off the car __***
Thanks
Thanks
RE: CAI C&L Sound, is it normal ?
When my filter is clean the sound is something like the sound of a four bbl carb opening up. If the sound you describe is more of a hissing sound, I think it may be a leak, just check your seals.
yes; to be able to hear air coming through any CAI is normal. some make more noise than others. i have a JLT2 and i only hear it at WOT; however i've heard others that you could hear under any kind of spitited accelleration
It's one of the benefits of a CAI.. more cool noises. Personally, I love the sound. It should sound like a sucking/hissing sound. For good measure though, check to make certain everything is tight. Have someone give your car a little gas has you inspect the CAI and it's connections. Standing next to a big cone filter as it sucks in tons of air will give you a better perspective.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
