driveshaft install
RE: driveshaft install
When I did my install I used a12mm 12pt.boxend wrench w/ the handle off the floor jack for leverage and that went well for me.
Oh if you have any viberation after install, unbolt the d/s and rotate flange thenbolt up and test drive again. Good luck.
ORIGINAL: GA05GT
i have a very slight vibe over 80, but i replaced the pinion flange so how could i get it indexed with the trans flange?
ORIGINAL: mac10chap
pinion flange right now...giving me some hell but i'm working on it...breaking out the mallet, the gear puller already failed
pinion nut came right off with impact wrench...easiest part so far[&:]
gear puller is a double arm puller...FAILED
going to get 3 arm puller or harmonic balancer puller now and either finish tonight or wait till tomorrow morning.......its getting to be about beer 30 anyways, i feel like i just got my *** kicked.........all day[>:]
i know for sure it'll come off easily with a harmonic balance puller, if you can get ahold of that, you'll be all set. if this is a four inch driveshaft, don't forget the relocate the e brake cable...and while you have the shaft out, it would probably pay to massage the floor board where that cross member is that's tacked to the floor board about half way back. i need to take mine back out and massage the cross member a little bit. it rubs occasionly just enough to put a little shine on the driveshaft
unless of course your car isn't lowered
yeah, it is finished and pulls significantly harder...only problem is when i decelerate, it whines and gets worse the lower the RPM's go....
i am not sure if this is being caused by the e-brake cable relocation, losing too much gear oil, or the need to rotate the driveshaft...
