where can i get GT/CS side scoops
RE: where can i get GT/CS side scoops
You can get them at the dalership but they're probably not cheap. They look good, though. I just don't like how their little "grilles" match the Shelby GT hood scoop and not the regular GT scoop.
Do yourself a favor and look at one mounted by Ford before you do it. I put one on mine and lined the template up with the front edge of the rear fender. After I drilled the holes, the scoop was backset about 1/4 inch from the door edge. Thinking this was not right, I elongated the holes on the scoop and lined it up with the fended edge just behind the door. Although it looks good like that (and I kind of prefer it) when I finally looked at one on a car dealership lot, it was suppose to be offset like that. So the template was right. Either way it looks good but decide how you want it before drilling into the side of the panel. There are several sources on the web that offer them but I could not find them pre-painted either. Had a body shop paint them for me. I liked these versus the aftermarket ones because they are secured on by two screws and tape. Others just use the tape and I wasn't sure if I could trust tape to stay in place long term.
