one time use fasteners
since installing my bmr lcas over a year ago there has been different noises on and off, no squeaking noises. i never bought new fasteners even though ford says they are one time use, does anyone have the part number for these.. is it just the bolts that hold the lca into the bracket?
RE: one time use fasteners
bump.. did anyone else reuse these fasteners?
One time use fasteners are ones which are not to be trusted after they've been stretched by the first useage as they invariably relay false torque information back to the torque wrench.
A lot of people do reuse them of course, it's human nature to want to save a few bucks on things which still look brand new. I've done it myself in non-saftely related areas. Anyway, you won't be getting noises or squeaks from these items anyway, unless they are tragically undertorqued (to the point of them being loose) so it's not them that's cauing it.. |
http://iihs.net/fsm/?dir=65&viewfile...ower%20Arm.pdf
They are an interference fit fastnermore than a yeild to torque fastner on the suspension. A little blue loctite and you are in busisness in the reuse department. ;) |
Lower Control Arm Front Bolt - W704886
Lower Control Arm Rear Bolt - W704888 Lower Control Arm Front Nut - W710089 Lower Control Arm Rear Nut - W704991 |
thanks guys i figured youd be the ones with the answers
This has some good info about One Time Use fasteners:
http://www.i-car.com/pdf/advantage/o...006/121106.pdf |
