Sponsored by:
Sponsored by:
aluminum driveshaft???
Old 07-18-2008, 12:35 PM
onederful100
onederful100's Avatar
Default RE: aluminum driveshaft???
ORIGINAL: antipeterleague
what are pros vs. cons?
not quite sure which DS i will go with, but for me the pros are lighter wt and holds more hp/tq. i am planning on doing this w/ clutch and aluminum flywheel if money permits. hoping it well get me quicker accelleration and hold more power. the cons are its gonna cost some $$$.
onederful100 is offline
Old 07-18-2008, 01:20 PM
mac10chap
mac10chap's Avatar
only con is the expense...i agree........unless you put it on wrong or something
if you dont torque the bolts down enough and loctite them, theoretically, they can walk out on you due to vibration and cause the driveshaft to fall off
some cause major vibration but that usually only requires them to be taken off and rotated 180 degrees and reinstalled, then usually no problems
like i said, install it right and there really are no cons to an upgraded driveshaft. i mean, a spydershaft with upgraded u-joints can support 900+ HP to the wheels
mac10chap is offline
Old 07-18-2008, 02:39 PM
americaniron
americaniron's Avatar
I got the spydershaft, and feel that it was definately a worthwhile mod.
americaniron is offline
Old 07-18-2008, 02:57 PM
jlaurens06gt
jlaurens06gt's Avatar
+ on spyder. tighter feel on acceleration, reduces thunking.
jlaurens06gt is offline
Old 07-19-2008, 10:56 AM
mjk150
mjk150's Avatar
spyder============rocks
mjk150 is offline
Old 07-21-2008, 08:30 AM
ShelbyDoc
ShelbyDoc's Avatar
Definately a worthwhile mod. You can feel the difference. My car is very lo and I have a 4" driveshaft without any problems. My 4" driveshaft weighs 17#.
ShelbyDoc is offline
Galactic
04-29-2019 02:56 PM
baddog671
07-26-2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Luke9222
10-22-2015 11:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Quick Reply: aluminum driveshaft???
