aluminum driveshaft???
Been thinking long and hard about getting an aluminum driveshaft. Are they worth the money?? I want to know if you can really feel the difference?, also approximate cost of install? What are some of the negatives(besides the money)?
RE: aluminum driveshaft???
in regards do your question, from what i've read here on the forum, getting an alum d/s will reduce the rotating mass and decreases the amount of HP loss due to friction since it's 1 piece. so you'll be putting down more of the flywheel HP to the ground. as far as feeling it, i can't vouch since i still have the stock.
also, depending on how much you've dropped the car is if you want a 3.5 or 4 inch d/s. if you are at stock height (which i doubt since i see you have the eibach system) then either diameter will be fine. but if you're dropped, the 4 inch will hit the ground.
20" Carroll Shelby CS66 chrome
Also thanks for the feedback, I am dropped about 1.5".
[IMG]local://upfiles/80900/1EE8A69E3F8E4195B67AEDA68AD9AC09.jpg[/IMG]
[IMG]local://upfiles/80900/5B3511C3CE684AC6945FD050234B6474.jpg[/IMG]
Don't see how the 4 inch could possibly hit the ground. I have the Coast Driveline 4 inch and am very pleased. Install was a piece of cake, meaning you should be able to do it yourself. I believe TacoBill did a How-To on it. You might (you should) get an an adjustable UCA being that your car is lowered. That will get rid of any vibrations.
The aluminum is definitely worth it. I have the 4" Shaftmasters and the car is completely different. Got rid of the shakes from the stock driveshaft, and the car accelerates quicker.
On a dropped car it isn't the 4" hitting the ground, rather the 4" will hit the car and rub the emergency brake line.
i just put a spyder d/s on my car and i love it...took a while to install due to lack of equipment and being prepared. before you install it yourself, get you a harmonic balancer puller, loctite, a 27mm socket, torque wrench, impact wrench, 12mm (12 point!!!) socket and you are ready to go.
if i had to do it again, i could replace the driveshaft in about an hour, no problems...
ORIGINAL: mac10chap
