Sponsored by:
Sponsored by:
Anyone have Steeda Pulleys?
Old 05-07-2005, 01:09 PM
jagbits
jagbits's Avatar
Default Anyone have Steeda Pulleys?
I installed the UD pulleys and I have a little squeaking only at start up, anyone else have this and does it go away?
jagbits is offline
Old 05-07-2005, 01:13 PM
Evil Sephiroth
Evil Sephiroth's Avatar
Default RE: Anyone have Steeda Pulleys?
I have them, no problems though
Evil Sephiroth is offline
Old 05-07-2005, 01:14 PM
jagbits
jagbits's Avatar
Thanks Evil I may take the crank pulley off and put it back on making sure I use the proper torque sequence that is stated in the instructions.
jagbits is offline
Old 05-07-2005, 01:44 PM
hawgman
I ♥ Acer
hawgman's Avatar
How about a little belt dressing instead? Not sure how the torque sequence of the crank pulley is going to cause you to have a belt squeak.
In your other thread about the misfire problem you were having you said that you wished you didn't order the pulleys and that they were not worth the time and money. If you are going to pull the crank pulley back off to retorque, why not just remove them all together since you are already there?
hawgman is offline
Old 05-07-2005, 11:48 PM
Redfire
Redfire's Avatar
You might check to see if you need a bit shorter belt. Maybe the tensioner is all the way out. I put u/ds on my Chevy truck, and it took a smaller belt. And at that, the one they suggested was too long. Got belt squeal at just a few thousand miles. I had to go to Napa and get one just a touch smaller yet. Been fine fer almost 30,000 now.
Redfire is offline
Old 05-08-2005, 12:04 AM
jagbits
jagbits's Avatar
I don't know about these pulleys, I here a knocking noise at idle also, sounds like something is not right... I may put my old pulleys on, something just isn't right, first I am going to try and locate the knocking noise, which is sort of a ticking noise, then I am going to take the crank pulley off and put it back on paying very close attantion to the toque specs in the directions, if I still hear the tick-knock noise I am taking both pulleys off and putting the old pulleys on, if the noise goes away I will return the pulleys for a new set.
jagbits is offline
Old 05-08-2005, 03:15 AM
hawgman
I ♥ Acer
hawgman's Avatar
There are several threads on the "ticking noise". Casper had a F150 in his shop that had it and said that he ordered new cam timing solenoids for it. Never saw if it fixed it or not. But it is the same ticking noise that quite a few Mustangs have had also. That might be the noise you are hearing.
hawgman is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
UrS4
09-30-2015 10:13 AM
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
Quick Reply: Anyone have Steeda Pulleys?
