aeroforce scangage not working
powers up, goes to set up, i put the star next to RPM (or anything else,ive tried a few), and when it starts scanning i get nothing,then the gauge goes blank like it not getting any info from the car.
anyone had this issue with this gauge?
RE: aeroforce scangage not working
yes,tuner worked fine. this aggrivates the hell out of me! i installed 3 gauges for my up coming turbo, this was the one gauge that was actually going to be used,lol.
all you did was plug it into the obd2 port and turn the car on correct,then just select what you wanted to see?
I've had a few issues with mine where the screen will go blank or it wont power down. I disconnect it from the ODB port and come back to it in a few hours and it works. Once I had to disconnect my battery for a bit so it would shutoff. I also had it go blank if I had a pid running that wasn't supported.
Fun, The only problem I have is that is the car gets real hot, easy to do in FL, the gauge face gets washed out. As it cools it comes back. I use a reflector for the windshield and when I use it I have no issues.
Galactic
04-29-2019 02:56 PM
