Center fog light grille...all the same??
RE: Center fog light grille...all the same??
how small are your hands? lol
i was trying to take out the stocker because initially i wanted to do a billet grille with hidden fogs but amazingly.... i decided i think ill like the honeycomb look better with the way my car looks.... odd
deekum, where did you get yours from?
my hand are not that small i just kinda pulled the grille out and and lifted the tabs lol i got my grille from and here is were i got it http://www.atlantaauto.com/ford_must...grilles_05.php
it looks good in the pic i ordered it when i went to install the fogs they didnt fit right at all it was a horrible design so i retured it it looked like it was home made it didnt look like a pro design
i used the 3D Carbon version - no pony. The clearances between the fogs and radiator support cross member were tight on my 08, but no bending/cutting of sheet metal or plastic was required. I have seen short cuts to installing this grill but I didn't want to scratch or break anything so I dropped the front fascia just like the 3DC instructions say to do. It was a tedious job but very simple, no special tools - just take your time, use an old blanket to set down the fascia. Use some old towels on your work bench to protect the old and new grills while you're changing out the fog housings. If you are thinking of going to clear corners you can easily make the front change out while everything is disassembled.
[IMG]local://upfiles/94784/0A4DE9011B1B40C492620FAD24FB81E0.jpg[/IMG]
i use to have both the 3d and the street scene. the first pic its the 3d u can see the foglight are closer together. the second pic its the street sceene grill and the foglight are farter apart
[IMG]local://upfiles/75778/61733A2C350F4F6C8BE0F2AFB986B088.jpg[/IMG]
[IMG]local://upfiles/75778/B3B991F0E5C944498C46839F3E8263B2.jpg[/IMG]
