Anyone install the Push-to-start mod?
RE: Anyone install the Push-to-start mod?
It's really not that hard to install. I takes a couple of hours. You can buy the switch from anyu Honda Dealer. IT's the same button as it on the S2000. You can use a connector from a floppy drive to connect directly to the swich and wire some extensions to get where you need.
The nice thing about this mod is that if you wire it as hown in these instructions, you can use the button to provide Aux power to all your accessories for a few minutes without the keys. I find it very useful. I use it to let my daughter listen to music in the car while I run errands. I also find it useful to put the top up or down, raise or lower the windows, etc without having to go and get the keys.
http://www.cherod.com/mustang/HowTo/Start%20Button3.htm
ORIGINAL: bb816331
ABORT!!! ABORT!!!
READ THE INSTRUCTIONS!!!
http://media.latemodelrestoration.co...LRS-11572K.pdf
Unless you guys are super amped on removing half your dash, including the steering wheel, I say to avoid this mod!!!
ABORT!!! ABORT!!!
ORIGINAL: yomofoitzjay
removing the steering wheel takes 2 mins at the most...
If you use the S2000 switch as I did, connecting a ground wire will make the Engine start light go on. This is avery dim neon light that draws very little power. This light is ALWAY ON. I' have had my car parked for up to 4 weeks and this light is not enough to drain the battery. If you are worried about it, you do not need to conect the ground wire.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
