handbrake not very good on stangs?
ok so my mustang's handbrake is first off kinda hard to pull up, especially compared to my grand cherokee which i almost rip out once i get used the mustang pull...and i sat in numerous 08's and they are the same way, then i sat in an 09 and it was a LOT easier to pull up and fell like it should be, i can also not lock up my brakes using my e-brake unless its wet and i pull super hard, is this the way it should be or what? thank you
RE: handbrake not very good on stangs?
lol wow thats funny, and no real reason other than i just didnt know if that was right or not since my jeep's is so easy, but i guess its a drum ebrake
A tight e-brake is good because that means you have plenty of pads left. if its really easy and you can pull it all the way up, it usually means either your cable needs adjusting or you are almost out of rear pads. You should appreciate your mustang's e-brake.
That would do it in the Jeep. I can always scare people by pulling it up making them think it will get out of control but it won't. Not enough to stop completely being that the pads are so small./
when making a U-turn in the middle of a block it would be nice to be able to e-brake and get the rear end sliding around.
Can't do one with the Mustang... is it because of my auto tranny?
