Need help with steering wheel shake... FIXED!
#21
RE: Need help with steering wheel shake...
If that doesn't fix it, its a wheel imbalance problem. You need your wheels balanced properly not an alignment. Find a place with a road force balancer. Also mustang does it at about 75 because of the driveshaft.
#23
i e-mailed tirerack.com to let them know about the problem, (i figured they probably already knew) they said there were directions on the invoice to take the clips off if they were there, who knew?!
#25
well, like i said in the OP, it is very slight, so slight i thought about just living with it, but i knew it wouldn't go away and it shouldn't be like that, and, being a perfectionist, knew it would drive me insane.
but yeah, that little thing... maybe with both of them combine, it was just enough at high speeds to put a little wobble in the steering wheel.
i haven't even taken the ones on the rear wheels off, if they are even on there, cause i don't feel anything from the wheels or body or anything, it was just in the steering wheel.
#29
ONLY in the steering wheel. i may still have the clips on in the rear, i don't remember if they were on there or not but if they are i haven't taken them off.
ORIGINAL: mpatilla
I have been hearing a slight vibration in the rear. Did you hear the vib or only feel it in the steering?
