Help installing GT 500 front Splitter
Just bought a new front splitter I know I've seen instructions on how to install them, but can't find them now. I need instruction on what needs to be cut out to fit on a GT. Thanks
RE: Help installing GT 500 front Splitter
basically just lay it on the ground under the bumper and you can see how you need to modify it. You will see that your GT bumper is lower on each side so what you need to do is cut the GT500 lip where it would come in contact with the lower parts of the GT bumper. Make sense?
You might want to look through this old thread. It should have good pointers or even links to other threads with pointers. Good luck. Partbill has done it if you want to hit him up for help.
Good luck.
https://mustangforums.com/m_3894166/...tm.htm#3894166
Good luck.
Shifty Magoo
08-25-2015 03:08 PM
inyadreems
08-21-2015 09:10 AM
