Is this an exhaust leak
Hi. I wanted your opinion whether the sound I'm hearing is just the long tube headers or an exhaust leak. So I just installed my long tubes and when I start the car I get a ticking sound that quickly disappears (Different from standard engine sound). Is this just the headers heating up or is it a slight leak.
Thanks.
Thanks.
RE: Is this an exhaust leak
Never had long tubes, but when I got my shorties installed on my 06 , the drivers side O2 sensor on the header wasa little loose, causing a ticking kind of sound. It goes away when the car is warm?? If so, then I wouldnt think it would be a sensor.
It probably is an exhaust leak. Once the car warms up, the metal expands and closes the opening. Just check all the bolts to make sure they are tight and you will be good to go.
trashxtrash
09-20-2015 10:49 PM
09-10-2015 08:39 PM
