Got my FRPP GTA's
Got my FRPP GTA's
I received my FRPP GTA's from Ninosport. Good service and the $299 price inc. shipping was nice. Only issue I have is that they did not include any instructions. Is the instalation as easy as it looks. Loosen clamps, remove hangers, transfer hangers to new mufflers, reinstall? I was going to send them an e-mail asking for instructions, but if I don't need them I wont.
RE: Got my FRPP GTA's
make sure you loosen the clamp near the h-pipe too!! i have the exact same ones!!! do not remove hangers!! just slide out factory mufflers and slide in new into the rubber hanger!!
ORIGINAL: 07vbluestang
ORIGINAL: rlh6805
Why loosen up the h-pipe clamps? Is it possible to remove the muffler w/o removing the hangers? I have had the drivers side clamp loose before in an attempt to get my factory mufflers tips aligned right. It didn't look like the muffler would just slide out of the hangers. There was not enough play at the over axle slip joint.
ORIGINAL: smokestang
Theres no need to loosen the h-pipe! just remove the hangers and unbolt at the axleback. its not that hard to get them on and off and you dont want to bend the new brackets ( GTAs bend real easy if your not careful)... should be fine! JMO
