Has anyone install the rear baer 2 piece rotors on their car? What's the weight difference? How about difference in weight for front rotors? Also, is there a company that make 2 piece rear rotors stock size?
Wow, I thought most 20's would clear a 12-14'' rotor... Guess not.
Offset issue?
Most other 20's and 18's in fact would clear BBK, but the bullet's design doesn't have enough room to clear the caliper. When I had the 20's the rims would barely clear the stock calipers.
Also to mention. The 20's bullet can clear the 14" rotors just not the calipers.
Yes there is a spacer on the front. I didnt want to go with spacers buts its only a 5mm. There was not many wheels to select from after I got the brake kit. Anyone looking to do this should keep in mind that the Brembos and this Baer kit have pretty winde calipers so not many wheels will fit. All 20"'s should fit the rotors though. Buff here is a picture
