Sponsored by:
Sponsored by:
Spark fluctuation (?) on datalog?
Old 09-02-2008, 11:21 PM
frarmar
frarmar's Avatar
Default Spark fluctuation (?) on datalog?
I datalogged my car last night and noticed some fluctuation in spark. I did a run from 2400rpms to 6k. Attached is a screenshot of RPM and spark from 4000rpms to 5900.
What i'm wondering is if anyone knows if the "V's" in the spark are normal?
--The first time they appear is from 4300 to 4500
--Second time is from 5100 to 5900.
Any input is appreciated...
Attached Thumbnails Spark fluctuation (?) on datalog?-datalog-screenshot.jpg
frarmar is offline
Old 09-03-2008, 05:14 AM
Doc Holiday
Doc Holiday's Avatar
I believe this is where the ECU is pulling timing for knock. I wouldn't worry, I have the same thing. ( I can post a picture of my datalogs if you want). As long as it's not a major dip (like more than 2-3 degrees) it's normal. It will try to run up to the max spark in the open loop table, but it will back off timing if the knock sensors pick up too much noise. This could also be false readings if you have alot of mods (especially exhaust, headers, or cams) that have changed the expected resonance and vibration of a stock motor.
Do you feel any vibrations (floor, shifter, etc.) ?
Doc Holiday is offline
Old 09-03-2008, 12:46 PM
frarmar
frarmar's Avatar
I don't notice any noise, vibration, or spark knock although my exhaust is pretty loud. In one spot where the spark "drops" it goes from 29 to 24.75. Please do post your datalogs, it would be nice to see some others.
Thanks for your reply.
frarmar is offline
Old 09-03-2008, 03:09 PM
spyder14
spyder14's Avatar
I was under the impression that our cars don't have knock sensors. Is that wrong?
spyder14 is offline
Old 09-03-2008, 05:07 PM
frarmar
frarmar's Avatar
I'm 99% positive we do.
frarmar is offline
Old 09-03-2008, 06:05 PM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
I am 100% positive that we do! .......
mygt500 is offline
Old 09-03-2008, 10:16 PM
frarmar
frarmar's Avatar
bump for doc's datalogs
frarmar is offline
Old 09-04-2008, 09:18 AM
spyder14
spyder14's Avatar
Good to know.
I'd like to see some datalogs too. Bumpety bump.
spyder14 is offline
Dathan
10-05-2015 05:52 AM
dalehunter
09-25-2015 10:51 AM
lmurf60
09-24-2015 10:07 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Spark fluctuation (?) on datalog?
