Whipple HO kit Q'a need some A's
I just bought A Whipple HO kit the only thing the kit did not come with was the fuel pump and Spark plugs. I dont plan on going more than 450hp on a Bama chips tune. I know this kit could put much more than that. I'm wondering if I could install with kit w/o the fuel pump and do this later. Does anyone know what the stock fuel pump could handle? What is the stock fuel pump rated at? I apprehensive about the KB b/p because I've heard that they fail or have a tendency of failing. Those with the Whipple HO kit or S/C please chime in.
Thanks
JP
AKA
Loots06
Thanks
JP
AKA
Loots06
You might be able to get away with the stock fuel pump if you mean 450 crank hp, but you will be on the edge.
You should either get a BAP or the GT-500 pumps.
I would go GT-500 as that is what the kit is designed for and they are a direct replacement. You just bought a S/C dont skimp on fuel. Whether it be pumps or what you put in the tank.
Good Luck
Good Luck
Its not worth the risk. The GT 500 pump ensures it can keep up with the engine's new voracious appetite for fuel at wide open throttle. If you run too lean your engine will go boom. So get the pump and get the plugs and rest easy that you have done what you need to keep the motor together. I assume you bought this used? If not, why did the kit come without the HO parts? I assume you got the uprated injectors? Also I assume you got the predator tune with the kit as its no use to the former owner?
agreed, GT500 dual pump kit would be #1 choice.
but if you don't want to get it, get the Kenne Bell
Boost A Pump, 38 or 39lb injectors and HT0 plugs.
this would be similar to the saleen stage 3 setup:
http://www.brenspeed.com/saleenstage3.html
Thanks
JP
AKA
Loots06
Thanks
JP
AKA
Loots06
the stock fuel pump is used on all my shop cars and I run 550 RWHP all the time and track the car 30+ times a year....sure I have blown motors but it was never due to the stock fuel pump.....for safety of your investment the stock fuel pump is rated for 500 HP
EDIT: I failed to mention I have 60# injectors as well and the car has been dynoed more than once and had to be re tuned cause she was running rich at 6000 rpms....this was with the stock pump and no BAP after the retune the cold start up thing was resolved and the car had 10 more RWHP....final numbers listed below
I also know in the back of my mind that if other components fail or the fuel pump that I CAN afford to replace the motor and go forged sooner than I planned. I think everyone that has FI should have at least considered this before going FI even with the GT500 pumps and BAP's and bigger injectors or fuel lines and fuel rails etc
and remember it's JMO
I hate the word kaboom, I dont want my motor to do that. From what I have read the stock fuel pump is rated at 500hp and yes it does not state if that is at the crank or at the rear wheels. From the looks of thing I'll be going with the GT500 fuel pump kit. Dam this was suppose be to on a budget but it looks like it will put my at around 4900.00 for the whole kit. That is with me and a buddy doing the work. I'll be sure to take my time.
GT500 pump FTW! I'd shop around though and try to find the best deal lol cuz there are some sites that advertise a LOT and have higher prices than the shops that don't advertise much online...and they don't always show up on page 1 of a google or yahoo search
