gone batty with the mods bug
seriously though i'm thinkin bout goin broke this week cause once i had the differential off that just opened up sooooooo many possibilities for suspension/handling mods. while it's off i could put in billet urethane lca's, steeda lowering springs, urethane bushings, aluminum solid driveshaft, man the possibilities are endless and it'll minimize wheel hop and my bank account.... gonna think it out long and hard
here's the procedure to get the differential out for anyone who's interested
you need:
a HUGE breaker bar about 2 1/2 -3 feet in length
15mm socket
18mm socket
10mm socket
rachet
chock the front wheels to prevent roll
jack the back up on the differential and put jack stands on the body
when you're done take the wheels off and now take the wheel speed sensor off by the brakes so it does not rip
here's a pic of it hanging after removing the bolt i just had to pull it out no problems there
next make sure tension is off the e-brake and take the tension clip off, wasn't too hard
after that push the cable off of the mount and you can then get it off the assembly
see how it disengaged? now you twist the cable off. repeat for the other side
next take the calipers off with the brackets as a whole assembly using 15mm sockets then hang them on the body
next take the sway baroff, you'll need to take the bolts on the differential and body off with the differential sitting at the very bottom to relieve tension (from here on is where i wish i had air tools it was easy getting the bolts to break off but then ihad to use a rachet to get it off quickly)
after doing both sides it came right out now put it aside
next take the panhard bolt off first take the cover off then the bolt on the differential and the bolt on the body. i had to pry down on the panahard at the body to get it off then put it aside
now we need to get the shock absorber bolts off so we can get the springs out
after removing the bolt push the shock absorbers in and put the bolt with the nut back on in the original position so you don't lose them
now lower the differential all the way down till the jack falls off it, you have to push it down alittle further by hand and the springs will come right out. make sure to put the springs back in the original position
next loosen the bolt on the trailer arm using a 21mm socket. just loosen it for now
you need:
15mm socket
18mm socket
10mm socket
rachet
next make a mark on the pinion flange using a 10mm socket so you put it back correctly and take off all six bolts note: i had to put it in drive the get them off and then put in neutral to rotate and gain access to the next bolt. take off the set aside
now loosen the lower control arm bolts which are the blue bolts you see up top(at this point i put it on jack stands so it wouldn't fall on me)
set the diff on jack stands and take the trailer arm bolt off (i used a hammer it's on tight!!! and also it will spring up so be ready it scared the crap outta me also at this point the differential got unstable so i had to hold it and it is not light so having a friend or two would help at this point
next pry the push the lower control arms down and now it should be loose. bee careful moving it, here's the final product here... then when i get the ring and pinion i'll be doing the dissambly of the diff and the measurements... should be fun!!!!
It adds up quick, doesn't it....? I still have a few things I'd like to do to my white car....my biggest thing is finding competent mechanics in this area. For instance....I paid dearly to have my gears installed, only now to have a gear whine and there is question whether or not I EVEN GOT THE RIGHT GEARS INSTALLED!!!
dam saddleup that sux i'd be pissed... the gear whine is usually caused by an incorrect pinion depth which i'm gonna explain later how to figure out.
but if the wrong gears were installed that's a problem too
btw yer stangs are awsome wish i had the gt500
i got the gears today, now just waiting on the installation kit. i should be starting it friday and then finishing saturday hopefully
like you said find a comepetent mechanic and if the right gears were put in hopefully it wasn't too far off and he can adjust the pinion depth if the wrong gears were put in or if it's FUBAR sue!!!!!!
