Spark plugs and dealers are fuc*ing idiots
So i did the plug swap today to Champions.
Took me an hour total. Got all 8 out after a bit of struggling and swearing.
Background story, 5 months ago, I had a new cylinder head installed by the dealership.
3 months ago, i had ALL the plugs pulled for a compression test because of a lumpy idle.
So i knew 3 months ago, all the plugs had been pulled by the dealer, and swapping them myself couldn't have been that hard.
Dealer had said their mechanic followed the TSB = no broken plugs for them.
On average, it should have taken 25-33 ft lbs to break the plugs loose.
How, in the blue hell, can it take ~ 68 foot pounds to break 7 of the 8 plugs loose?
I am absolutely speechless.
I did it at room temperature, engine cold, used Gunk super penetrant ( local stores dont store PB blaster / aerokoil, didn't bother going to Ford for carb cleaner )
The plugs in the new cylinder head were nice and clean.
Drivers side was pretty dirty with carbon build up.
I'm just happy I got the plugs out w/o any problems.
Plugs have 30,655 km's on them.
so when should we do this and which plugs should we use???...i dont have any problems with the car idling or whatnot but im creeping up on 41k miles so i would guess i need to change them....lets hear it from the experts...
are those plugs in the pic the order of which they were pulled, that would explain a lumpy idle. 4 of those plugs dont look healthy, the other four look ok. If you care is stock, i would check the new plugs in a month, if you put enough miles on the car, and see if they do the same thing. That doesnt look right
