Sponsored by:
Sponsored by:
Best tires for 19''s?
Old 09-16-2008, 09:17 PM
Mr.Bape
Mr.Bape's Avatar
how does the rear fill out? any pics?
Mr.Bape is offline
Old 09-16-2008, 09:43 PM
jdmcbride
jdmcbride's Avatar
245/45/19s would fill out the wheel well better as they have a diameter of 27.7". The factory tires are 27.0" - 27.3" diameter depending on whether you have 17s or 18s.
275/40/19s would be too wide for 8.5" wheels. But would fit great on 10" wide wheels and still maintain a 27.7" diameter.
jdmcbride is offline
Old 09-16-2008, 09:50 PM
EagleStroker
EagleStroker's Avatar
Hope that helps, if you want more i'll dig out some from the rear I know I have some on my portable hard drive
EagleStroker is offline
Old 09-16-2008, 09:52 PM
hmartine
hmartine's Avatar
sorry duplicate
hmartine is offline
Old 09-16-2008, 09:55 PM
hmartine
hmartine's Avatar
Default 19 in tires
f you are using 8.5" wide rim this translate to: 8.5 x 25.4 = 215 mm wide. so to keep the stock rear tire dia of about 27 in you would need the following tires size:
255/40/19: because 255 * 25.4 =10.03" * .40 = 4.015" x 2 = 8.031 + 19"= 27.03" which is exactly what I am using, pirellis Pzeros
a 255 width tire equates to approx 10" wide tire
so a 10" tire on a 8.5" rim leaves you with about 1.5" of tire . then / 2 side = .75" of tire shoulder on each side of the tire. take then about 1/2" of rim lip with on each side and you got about 1/4" overhang of tire on each side of the rim. Perfect so that your rim lip is not exposed beyond the tires rubber protecting the rim from curbs and other obstacles....this how I calculated the tire size I needed so that my speedometer did not go crazy with big tires....did not make this up. it really is straight forward math.....
hmartine is offline
Old 09-16-2008, 09:57 PM
EagleStroker
This is definitely true, I only went with the 8.5 b/c it was a package deal on tire rack got a lot off, i'm going with a 10 when I buy new ones
Old 09-16-2008, 10:06 PM
jrhykushi
jrhykushi's Avatar
i think you should definitely lower the car a little bit b/c fat tires can only do so much
plus, nyc roads arent THATT bad.. lol
./sarcasm
jrhykushi is offline
Old 09-16-2008, 11:57 PM
Mr.Bape
Mr.Bape's Avatar
thanks guys for the info! im just waiting on someone now to pick up my "bling bling" wheels lol.
Mr.Bape is offline
Old 09-17-2008, 12:17 AM
EagleStroker
Lol hurry up to wait, story of my life, keep us posted on what ya end up with
Old 09-18-2008, 01:37 AM
Mr.Bape
Mr.Bape's Avatar
will do as soon I sell.
Mr.Bape is offline
Quick Reply: Best tires for 19''s?
