Sponsored by:
Sponsored by:
Spray tint on tails?
Old 09-16-2008, 10:06 AM
VerginaStang
VerginaStang's Avatar
Default Spray tint on tails?
Which one is most commonly used and gives the best results??? I am going to pick up a spare set of tails from a buddy, and would like to spray them.
For those that have done it, what are the steps you took to get a quality finish??? Not sure if maybe some sanding, clear coat, etc. etc.
someone give me some ideas.
VerginaStang is offline
Old 09-16-2008, 10:28 AM
5SPD07GT
Official Site Sponsor
5SPD07GT's Avatar
i used vht niteshades but i took a differant approach then most people. i didnt want the glossy finish,i wanted more of a matte finish to match my stripes. basically i just put several coats on did a little wet sanding, then a coat or 2 of clear. i am more than happy with them
5SPD07GT is offline
Old 09-16-2008, 02:51 PM
VanWilder
VanWilder's Avatar
use the vht nightshades...works great!! put on as many coats as it takes to be as dark as you want it but make it a little darker as you will wet sand some of it out...after the tint is dry wet sand it with 1500 grit sand paper with a sanding block to keep a relitively even sand then wet sand again with 2000 grit...once it is all sanded and smoothed out polish it with a low speed orbital buffer with a nice eurothan polishing compound..i used blue corral products...once it is polished you are done and it will have a nice gloss finish
VanWilder is offline
Old 09-17-2008, 12:08 AM
lrgnation
lrgnation's Avatar
-prep lights with soapy water.
-spray lights with vht overlapping 50% assuring wet gloss look when applying.
-make sure application is in low dust area
-allow 5-10 minutes inbetween coats
-Use a clear laquer or clear coat and apply 2 -3 coats in teh same manner 5-10 minutes after you just sprayed vht.
-Allow overnight to dry and wet sand with 1500,2000,2500,then 3000 for best results.(careful on edges)
-Use any rubbing compound after that and go to town if you don't have an orbital no big deal.
- after 1-3 times using the compound give it a good wax with a normal polish.
Remember if it does not work properly use a laquer to remove the paint. You can find this at an auto supply paint store.
lrgnation is offline
Old 09-17-2008, 10:06 AM
shanec
shanec's Avatar
I've not done anything yet. But I'm falling into the "not permanent" camp. I might not like the result. Worse, the police might not like the result. I'd like to be able to easily undo tail light/relector/signal ting. So I'm thinking about going with autobadges.
shanec is offline
Old 09-17-2008, 10:19 AM
VerginaStang
^ I'm in the same boat as you, however my boy just sold his mustang and is giving me his old set of tails (he had some aftermarket tails when he sold it).
chrisdbassplayer
10-13-2015 06:53 PM
guitarman376
10-11-2015 01:47 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
robjh22
Suspension
09-08-2015 12:47 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Spray tint on tails?
