dumb question, but what is rev matchin, should i be doing it?
I keep hearing the term rev-matching? What does it meean exactly. I have a 5pd, should i be doing it? I suspect giving it gas to match the revs when you downshift hard, but is that necessary?
using the clutch/trans to slow down isnt the best thing for it, but rev matching incorrectly can be bad also. best bet is to just use the brakes to slow down and when you need to downshift, just put the rpm's about where they should be (this is where memory comes in) and just normally let the clutch pedal out.
Here is the technique I use (not all the time in day to day driving but always on a track):
Heel-Toe 1
Heel-Toe 2
Heel-Toe 1
Heel-Toe 2
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
