Where is the How-To on changing your headlights?
i couldnt find it in the search option and i will need to change my headlights out soon so i wanted to print out the How To guide....any help?
You gotta remove the front bumper. I've had to take mines off to put window tint film on them and I figured it'd be better if I got them removed. Been a while, but I remembed that I took them off side by side so I didn't have to remove the whole front bumper and I suggest u do the same so you don't have to mess with the headlights. Also, I think to lower bug deflector (the one under the car) had to come off in order to perform the procedure. The inner fender cover (the plastic inside ur fenderwell) had to be partially detached, but not completely removed. Also, right next to your headlight assembely by the fender the bumper has some plastic clips. No special tool was needed for that, after all the necessary screws came off I just pulled the bumper cover down and it came lose. It's pretty self explandatory, and as much as I hate working with body/interior to me it was an easy thing to do. Just take a look at it and take your time as you're doing it. There's really nothing you can mess up, not unless you intentionally do it.
http://www.youtube.com/watch?v=KJRMML21Elg
Alright, Olvanish, thanks a lot for the tip...just one question....how much of a danger is there in the bumper cover being too loose for some odd reason after reinstallation?...the reason i ask this is because i dont want to be like a lot of those little ricers and other poot cars that had bad installation jobs for their body kit front bumper causing them to sag and leave gaps between the contact areas...
TOMBSTANG, where is the link?
