Sponsored by:
Sponsored by:
When is a dyno tune not a dyno tune?
Old 10-03-2008, 01:04 PM
BruceH
BruceH's Avatar
Default When is a dyno tune not a dyno tune?
Learn it yourself. I'm done.
BruceH is offline
Old 10-03-2008, 01:09 PM
Hufenstang
Hufenstang's Avatar
its a lot more than that, my tuner started from scratch basically took him almost 4 hours to tune my car just how i wanted it..
Hufenstang is offline
Old 10-03-2008, 01:12 PM
D_Gusler
D_Gusler's Avatar
It all depends on the car. In your situation with the mods you have done, what they were doing was probably fine. I know of plenty of people/shops that start with a base file and tweak it to your cars specific needs.
D_Gusler is offline
Old 10-03-2008, 01:17 PM
Nuke
Nuke's Avatar
I'm not dyno knowledgable, but what diff would it make whether they start with the stock tune or a canned tune, as long as they know what to adjust to get where you want to go? I'll keep an eye on this one as I'm sure I'll become more edge-u-mucated as the experts post...
Nuke is offline
Old 10-03-2008, 02:23 PM
cobra443
cobra443's Avatar
Most tuners will just modify an existing tune, much easier and cheaper. However if you did a full build or something that would probably start from scratch.
cobra443 is offline
Old 10-03-2008, 08:26 PM
Moderator
JimC's Avatar
It is a lot easier to edit than it is to create - so what I've seen is that the tuner will start with a tune and then adjust on the dyno for what needs to be done to accomplish the results.
JimC is offline
Old 10-03-2008, 08:56 PM
BruceH
BruceH's Avatar
BruceH is offline
Old 10-03-2008, 09:24 PM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Jim and Cobra are correct.....some dyno tuning is from scratch (can be very expensive like writing the actual code after datalogging) and others are from existing tunes tailored to your car and its spec needs to run right and safely. Remember that not all motors are the same even if we all have 4.6L 3V etc....... JMO
For instance I had a tune done for my Whipple and it was based off the Whipple procal tool and fine tuned from there spec to my car and supporting mods. The tune was not "right" so some additional tuning was done and "perfect" for me (might not be for others) and later after other mods or just some tuning in general you can data log a few WOT runs and have the car tuned for driveability, more HP/TQ, set different shift points (for autos) etc....
mygt500 is offline
Sixx
10-05-2015 07:36 PM
Explosive
10-02-2015 07:45 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Florida Regional Chapter
09-30-2015 08:04 PM
RCS02v6
09-29-2015 01:46 PM
Quick Reply: When is a dyno tune not a dyno tune?
