Stainless Steel hoses part numbers.
I know its a little late.
They are all spectre brand.
2260 x2
29390
29490 x2
39690
Sorry I typed it from my blackberry and I guess it didn't take the enter button.
2260 x2
29390
29490 x2
39690
This will be the one from the Air Elbow on the passenger side, the small radiator hose, the other valve on the other side and a couple of the small vacuum lines which you can't see cause they are covered by the shaker but are on the drivers side.
Thanks Boozshey. What website did you get these from? Directly from their website or somewhere else? Also do you think I could still use the same smaller radiator hose on driver's side, but mine will be lower?
I bought all mine local from pepboys...
You can also get them here... http://www.partsamerica.com/
The passenger side rad hose is 1.5 inches. The driver side lower one on an 05-06 is smaller than that. But I don't know what size...
Honestly, if you only do those three it will look strange.
But you will need the 3/8" line and then of course the 1.5" radiator hose.
The 2/8" would be the 29490 part number and the extra cap would be 2260 and cut to fit. Be sure to use electric tape to keep the braided hose from fraying then cut with a dremel cut off wheel.
