Anyone have bullet lug nuts?
If so, can you please tell me the outer diameter of the nut driver. Trying to see if it will fit in my razors.
These are the lug nuts
if you need lugs to fit in your aftermarket wheels you can get lugs that take a large hex key that goes inside of the nut instead of a traditional lug nut that uses a socket to go on the outside of the nut. gorilla lug nuts is the name of the company I went with. steeda sells lugs also which are the gorilla units.
Those are prolly pretty good. I got the Wheel Installation Kit from American Muscle. It has everything you need. However, After taking the wheels off and putting them back on a coupple of times, the coating on the lugs started to peel and flake apart/off. It still has its chrome colour but will probably be more susceptible to rusting or something. They are still in good shape now though. Just a heads up to be careful if you choose to go with those instead of the bullet lugs.
