Fuel coming out of my Loudmouths ???
According to some very quick searching, common gas is C8H18, and it produces H2O and CO2. So if you balance that equation you would have C8H18 + Heat + Oxygen >> 8(CO2) + 9(H2O). So that would give you 162.05 grams of H2O per 114.2 grams of Gas. The density of gas is ~.75 g/cm^3, which gives you 152.3 cm^3 of gas. Density of water is ~1 g/cm^3, which would give you 162.05 cm^3 of water. So those numbers would give you 1.07 gallon of water per 1 gallons of gas burned. I think that is right. So yes, 1 gallon of gas makes 1 gallon of water. But most of that would be burned off im sure.
yea what he said.... uh....
