Cams/Heads Vs. SC
This might be kind of long, but I need some help with a couple issues.
I am definitely looking for an increase of hp on my car, but I don't think I'm ready to drop 5000 on a supercharger yet. I love the way the cams and heads sound, and I know they don't give as much hp, but they can also be a pre cursor to a supercharger right? How much would it cost for heads and cams, plus the install compared to a supercharger? Could I just get cams and just run with those for a while? I would need a tune with both right? What are good brands to go by? Like I said I know this is kind of long, but I've got the itch to buy something, and I'm really needing some help right now. Thanks a lot guys and I really hope to hear from you on this. |
I like the heads cams idea, just get some that will support a blower down the road and it's all good
make sure u research the cams cuz i member reading people having idle issues with some brands...
+1 also look into cam phasers depending on how aggressive the cams are. Without a tune you can have oiling issues at lower rpms, also depending on the cam profile though...
Do you know how much or maybe a good brand to go with? PS...I always loved your sig eagle
Appreciate it man :D and i'm running Crane, but i've heard some good and some bad reviews about the frpp hot rod cams. I don't care for the sound but if you bumped the rpm some you wouldn't have as much of a lope, just depends what your after. Won't be cheap though, problem with an overhead cam motor. At least it's not 4 cams like a GT500... :)
make sure you research because some n/a heads have actually seen losses when throwing a S/C on, same with cams. Theres a reason there are blower cams, and then N/a cams. You wont get near the power with n/a cams and heads as you would blower cams and heads with an s/c and that seems like it would be a waste to me.
That's what I was trying to suggest also, depends on your application
heads are expensive. if you want to do something now, go for the cams. you ever thought about N2O?
Nitrous always scares me. And whenever I say that people call me a p*ss lol
