something wierd happened and I have a question
This morning backing out of the garage I poped the clutch and killed the engine. At first the dash had a very eleictrical noise like everything was frying, then every thing went dead. The car would not even turn over. I let it set for a minute, then started to pull the battery cable in hopes of reseting everything. All of a sudden the alarm stared going off. Once I reset the alarm everything was ok. She started rigth up and ran fine. The only thing I had to redo was the clock.
Has anybody else had this happen or was it just an anomaly.
Just a wild guess but from your description I think you may have had a loose or dirty battery terminal connection unless you have some other intermittent connection somewhere. Something like that can be very hard to find. I hope it doesn't reappear.
If your cable were good like you said then you have a bare wire somewhere. Since you could hear it inside your car I would start looking for lose wires or a wire that is making contact with metal or very very near a metal edge that could of cut into it. Stuff like what happened to you doe not just happen as a fluke. Something is electrical is making contact with something its not suppose too.
LivingInThePast
09-16-2015 12:20 PM
