GT fog light wiring harness and switch
Check here:
http://www.mossmustang.com/Shop/View...eIndexID=53554
Not sure if you've already bought the parts but this would be everything you need.
Otherwise if you've already bought the grille and lights then check here:
http://www.mossmustang.com/Shop/View...eIndexID=48596
055-579 $76.46 Street Scene GT Fog Lamp Adaptor Harness
Note: When adding the GT Fog Lamps to your 4.0L this harness will make it plug and play instead of hack and splice.
Is the harness and switch.
Check here:
I found a photo of the harness... let me see if I can find it again.....
Can't find the photo... but believe its just a rocker... or you can buy the GT panel and wire that in I guess....
Yeah, it's a round rocker switch & looks quite like OE when installed. To install the fog control switch, you pop out the headlight switch assembly from the dash & drill a 20 mm hole in the upper right corner area. The switch snaps into that hole.
I JUST did this with the Street Scenes harness over the weekend - it's super EZ to do... comes with great instructions. Careful though, the fogs stay ON when you switch to high beams.. that's illegal in some states.
