Hood cracking, need paint ideas
Hey guys i have a problem. I have a carbon fiber hood and aparently when you put hood pins on, you are supposed to take the latch off? well anyways it started to crack a little bit in the clearcoat as well as in the CF where i have marked in the picture. So, the guys at the shop said i need to patch that up with some kind of compound (putty) and paint over it or else it will continue to crack. So, they said i will have to paint black over the red circle area. Any ideas of any kind of paint pattern that wouldn't look stupid in that area? Any suggestions help.
I have never heard anyone say that if you put hood pins on your car to remove the hood latch. The hood pins should be installed in such a way that when you close & latch your hood, your hood pin is sticking through just enough where you should only have to apply very little pressure to slide the hood pin latch through the hood pin hole.
As far as repairing carbon fiber, I'm not too sure how that is done because of the carbon fiber pattern.
It originally started cracking because i didnt have hood pins and it was putting stress on the hood where it attaches to the latch. Now the fibers are cracking there in a small spot. He said i shouldnt had a latch, but i guess he is wrong
never heard of taking the latch out either when putting hood pins on either... still have my latch and my hood pins clear the hood... i was thinking of getting the CF hood too but now i'm thinking about problems with the CF....
Maybe a flaw in the design?
The striker for the hood latch is bolted to the brace witch isn't connected to the outside skin...
I suspect that the vents opening are creating too much lift for that area that's cracking.
That means it will keep cracking even if you paint the damn thing.
I hate for you to spend a whole bunch of cash for paint and all, and be back to square one after the expense.
Take the car to people that work on Vettes or boats and see if they can work a remedy for you.
Good luck.
Good luck.
