Clutch and what else?
I want to put a new clutch in before the Whipple get installed to save time later. I have to money now so what the hell right? Anyway, I was researching the archives and a couple of other sites and found that 90% of the people running some type of FI have either a Mcloeod or CenterForce clutch. Can someone exlplain everything that I need for this kit?
http://www.lethalperformance.com/pag...10-spline.html
Thanks in advance for the advice.
You should be set with the kit itself. I would recommend you get a new TOB if you have alot of miles on the car. DO NOT buy an after market TOB but a new stock TOB from Ford . Cant hurt to replace while the tran is dropped and it doesn't cost much and may save time later on if the bearing craps out on you.
I am buying the billet steel flywheel from Mcleod as well but you can just get the stock one resurfaced if it was not warped or damaged from too many WOT runs with DR's or MT's or track runs in general
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
