lowering the 500
#21
The car will shift to one side so one wheel/tire will sit outside the fender while the other side sits inside the fender. I have the BMR adj panhard and no complaints at all. Price wasnt bad as i got during a group buy. Steeda will be good also but cost more probably. See if the guys over at Stangsuspension can hook you up with a forum deal perhaps on a package.
http://www.stangnet.com/Tech-Article...ll-061230.html
Some offset, maybe 3/8 inch, comes from the factory actually on the GTs. When you add the springs, you can increase that by a bit and get maybe an inch, .5 on each side, out of spec
BTW, front height from the ground to the top edge of the fender wheel well was 28 1/8 inches. Rear was 28 7/8 inches. This is with 17" wheels and 235/55 tires (Nero Zero's with 2500 miles).
#22
#23
Get any spring you want and a adj panhard bar to re-center the rear....Tacobill has a write up on the install and you could do it yourself. very easy IMO and I am not a mechanic. You even get the torque specs for the one time bolts that Ford uses. If you cant get them to stay at the recommended ft.lbs (129 ft/lbs for the LCA's for example) then go to the dealer and get new hardware for the suspension parts that were replaced. Lower that beast! I know you have been talking baout it in other threads.....so do it and you will not have any regrets!
#24
These guys make a watts link for our cars that's half the price of the Saleen...
http://www.fays2.net/index.html
#25
Most people go with the Adjustable Panhard bar, but if you want a way to "prevent it," the answer is getting a Watts Link. The Watts will never get out of alignment side-to-side even under compression. you really don't need it unless you really push the car on a track, but some people like it on the street, it will also fix that side-to-side motion the car makes when you go over a bump on the freeway sometimes; you know how the back end will feel like it's kind of stepping out?
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
