JLT/91 Octane installed! Few questions.
Ok, so I get off work and my stuff is here! Got it all on and man I am so glad it finally came in. Anyways, few questions for those of you with this setup:
First, is it just me, or does the JLT intake seem kinda cheap? The heat shield is the biggest P.O.S. and I don't like how it can move side to side. I want to tighten it more, but I feel any tighter will crack it.
Second, did you guys have a hard time with fitment? After it was all said and done, it kinda felt forced (the intake). Also, the rubber elbow kinda has a slight bend in it, but I guess that's ok? Anyways, other than that, everything went fine. Roasted the tires a few times
My JLT fitment also isn't the best. My filter rubs on the hood insulation just a bit. I tried adjusting it several times and the best I can do is a slight rub. I think the plastic sheild should have been cut out for the filter a little more and it would have been a perfect fit.
^^Yea, kinda made me wish I'd gone with the Steeda, but just couldn't shell out the extra $100 for it. What about the rubber elbow? Do you have a indention with it? I'll take pics later of the whole setup just to make sure.
Yeah the JLT seems cheap. Look at it this way. I've had mine on for over six months now without any problems. But my friend who has a Steeda has had problems with his coming loose. Also seen threads here about the same problem.
It may be cheap but it works and holds together fine.
I have no issues with the rubber elbow....just the cone rubbing against the hood liner. One of these days when I decide to dress up the engine bay I will just buy a new CAI...but that wont be for another year or so.
My cone rubs the hood liner too. Also, the heat shield does not seal or even come close to touching the hood liner. Others have nice rubber stripping on the top edge of the heat shield to help seal againt the hood liner. I've also never had any problems with it coming loose.
I've never understood why these are called "Cold" air inductions anyway. There's nothing cold about them since air is being pulled from under the hood. They're not like the CAI's on the Fox Mustangs that put the filter in the fenderwell.
Only thing I can guess is that the shields on these kits are meant to prevent fan wash, not to shield the filter from heat. Who knows...
