Sponsored by:
Sponsored by:
Plan on buying a set of Nitto 555
Old 11-29-2008, 09:39 AM
Va. Stang
Va. Stang's Avatar
Default Plan on buying a set of Nitto 555
295/45/18" They are about 28.3" tall compared to 26" stock height tires. I am lowered with EB pros and was wondering if anyone is running that set-up and do they rub the fender-well. I need the taller tire to help out with my gearing. I am coming up alittle short on gear at end of 1/8 and 1/4 mile runs. Plus first is done before you can blink. Da#n quick though!
Va. Stang is offline
Old 11-29-2008, 09:45 AM
EmperorOfChicken
EmperorOfChicken's Avatar
i was lowered on FRPP K springs and ran 285/35r20 555s and didnt have any problems, and i mean the car sat LOW. but thats with 20s, i think the fact that you have 18s you should be okay...but maybe consider a 295/40r18? right now im on stock springs out back with 305/35r20 555rs
EmperorOfChicken is offline
Old 11-29-2008, 11:50 AM
olvanish
olvanish's Avatar
I've tried that setup about 2 months ago and they didn't rub. Can get you pictures of how it looks if you want. I, however, was happier with my Falken 275/40/18 and that's what I switched back to. If you want 2 Nitto tires that size with about 20 miles on them it's 340 shipped (you can still see that green stripe on the tire so you know it doesn't have more than 20)
olvanish is offline
Old 11-29-2008, 07:05 PM
Va. Stang
Va. Stang's Avatar
I need the 295/45/18 for the height. I am looking for 28" tall tire. But I only have 2"clearance now with 26" tire. I will only have 1" clearance with the 295. Afraid it might rub?
Old 11-29-2008, 08:29 PM
Heavyg72
Heavyg72's Avatar
I'm running those in the rears with the Roush springs. No rubbing issues as all.
Heavyg72 is offline
Old 11-29-2008, 10:16 PM
SirKnightTG
SirKnightTG's Avatar
I thought stock was 27".
SirKnightTG is offline
Old 11-30-2008, 01:49 AM
So_Cali
So_Cali's Avatar
You shouldnt have any problems at all. I have 555's all the way around with the Pro-Kit and have had ZERO rubbing issues.
So_Cali is offline
Old 11-30-2008, 03:10 AM
olvanish
olvanish's Avatar
I've had these tires on with my FRPP springs and 18DD bullitts-- no rubbing. From what it seemed like even 305 could fit. My main concern was not rubbing on the inner side, but on the outter one (the 1/4 panel) here ya go:
Attached Thumbnails Plan on buying a set of Nitto 555-rim.jpg   Plan on buying a set of Nitto 555-rim2.jpg   Plan on buying a set of Nitto 555-rim3.jpg   Plan on buying a set of Nitto 555-tire4.jpg
olvanish is offline
Old 11-30-2008, 08:43 AM
rshamekh
rshamekh's Avatar
I have the same setup, Eibach pros with 295/45/18.
No rubbing whatsoever, especially that you have the adj. panhard bar.
rshamekh is offline
Old 11-30-2008, 09:32 AM
DarkFireGT
DarkFireGT's Avatar
I'm running this combination as well. No rubbing. Looks awesome! As stated above, make sure you get an adjustable panhard bar.
DarkFireGT is offline
Quick Reply: Plan on buying a set of Nitto 555
