Lowering Springs - 2 questions
2 questions
1. So i talked to Brenspeed yesterday and they told me in order to get lowering springs i have to get caster camber plates ($300) or my upper strut mount WILL break soon after install of springs. Ive never heard of anything like that, and normally brenspeed isnt trying to drain my wallet, but it just didnt make sense. I went to ford and had them replace the upper struts already because of the TSB
2. I remember hearing something about when you get upper and lower control arms you need one or the other adjustable if you are to lower your car. I didnt know this at the time so i dont have adjustable, Can i not lower my car until i get that?
THANKS!
THANKS!
2 questions
THANKS!
THANKS!
2. You'll only need adjustable control arms if you need to adjust the pinion angle of the drive shaft. You may however need LCA relocation brackets to compensate for the angle of the LCA once the springs are installed.
3. Both of the above answers are null and void if you race the car on a regular basis, go for the heavy duty stuff if that's the case.
Anyone care to back me up or disagree? Fire away!
grr this sounds like a pain in the ***... i dont know how the hell to check the pinion angle, and im not taking it to a shop to do the spring install. My step dad can easily do it.
the search button helps alot. But I have had my prokit on for about 11,000 miles with zero problems. no camber plates, no ADJ panhard. just the springs. It rides a little bumpy but that nothing some D-specs can't fix.
hope that helps
hope that helps
all i have is lowering springs, adj. panhard bar and panhard brace. car's been fine for 6 months. camber appears normal. wtf is the pinion angle and how do i check it?
the ride is smoother than before, the car handles like a dream, etc.
It's simple to adjust...
LCA Suspension Modifications and Adjustments
