mlcrycc...thanks for the pics, so does the trim piece attach only with double sided tape?
Yes, it is held on only with 3M tape. There are some alignment pins along the bottom of the grille, but they do not clip. They are strictly alignment pins. Be aware that this trim piece is NOT aluminum, but rather aluminum looking plastic....
Yes, you can buy the Bullitt Grille, it runs about 200 bucks.(partscheap) You won't find them at newtakeoffs however......
Mike
That is so ironic you should say that...because I was just looking on partscheap.com and found it for 201.26.
is there a way you can get the the Bullitt grille without the trim (doubt it) or how can the grille be modified so that the trim looks black (besides spray paint).
But I am looking for the trim piece..., or is this a seperate question?
