More gauge questions!!
Ok guys I've gotten a lot of feedback, and GT500 great write up I needed that (and the electric fuel pump is coming). I'm going to go ahead and ruin the surprise so ya'll understand what I'm trying to do here.
These are some pictures are what I'm going to do, I want something that is different but not particularly gaudy, I like clean. This is the general idea, I won't tell you everything but I'm going to set 3 gauges up like this:
I drive my car a fair amount, but I also do a lot of shows so that's what these are doing. At the same time, I'd like to spend my money on something I'm going to get some use out of. I'm slowly upgrading my car with all the things that make a blown car great, so that if I ever cross that bridge I've deleted the "hidden costs" associated with them.
As far as the Interceptors I will be buying a pair, but the cost of those gauges is the cost of this whole little set up honestly, it can wait. I plan to buy a pair along with a wideband and throw them in an SOS pod but like you said that's close to a grand right there.
And GT500, as far as the show mode you were referring to - is that only on electric gauges? Is it available in their Cobalt Series?
That's not mine, but the AC is in the center console, so you can close it and it's out of the way. I've got a lot more coming together than just that, I just really need to pull the trigger on the gauges.
I promise I'll do a write up for you guys, I've taken to much from here not to give back some.
Looks like your a man with a plan and I think the gauges will serve you right esp in the locations you chose. Post it up when done and I look forward to seeing it when done.
That car looks like Chevykiller's from the pics?....maybe?
That was originally done by Hillbank Motorsports on a Shelby CS8, I tried to contact them on it but they didn't respond. I test fit a friends gauge in the panel and have got that worked out, I'm still deciding what I'm going to do with the AC as I really like my console, I may work it into the side of the center console itself, drivers side towards the front, would be sleek I think.
All it really is will be running, splicing, and lengthening wires. If I'm lucky i'll gut another defroster switch panel from another car and stick something sneaky in it!
Off topic, but can anyone find out what head unit that is?
