Get whatever brand you can find a good deal on, just make sure it's adjustable. Steeda, BMR, CHE, Spohn, or UMI are all good choices. If this is a DD, get Poly bushings or maybe a combo type with a Poly on one end and a Heim on the other. If you do a lot of track events or AutoX's, you might want to go with Heim joints on both ends. One thing I'll mention, though, is that if you go with the Steeda that has regular Poly bushings, it's maintenance free... never have to grease it. With the others, you might have to grease them periodically. If you do go with one of the others, I think BMR uses grease fittings that would make the periodic greasing much easier.
This is a DD I don't think its gone more then 4 days in the past 4 months without being driven at least 25 miles haha so I defintely want the easiest one maintenance wise.
Though, now when I read the description, it doesn't say anything about maintenance free bushings. I know their LCA's are maintenance free and these look like the exact same bushings, but you might want to call and double check.
